Results 1 to 3 of 3
Thread: Restore original scanner layout
    Jan 2021
    3
    I messed up the vcm scanner layout accidentally deleted some things can?t load pic to show . Was trying to figure out wideband . Pretty frustrated , about to give up . Hope someone can help
    13,565
    Should be able to click the layout at the top on the scanner and then down to default layouts. Just pick which one you want as the default.
    You can right click the channels list on the left and add back in whatever channels you want as well.
    Jan 2021
    3
    That worked thank you ..
