I have 16 2.0 ats 8 speed, when going wot it falls on its face, I also have hp tuners mpv12, can someone tell me which files to change to correct that, also which files to change to raise the torque limit. thanks
Not a point and click answer, many things can cause this, many tables effect torque management and limitations..
Post up a Tune file, all modifications, and a Log, probably better to post in the GM GEN 5 section...
Basically you need to log your AFR or EQ Ratio error to adjust your fueling, then you move into spark tuning...
2011 Camaro 2SS Convertible L99 Bone Stock for now
2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
