Page 7 of 8 FirstFirst ... 345678 LastLast
Results 121 to 140 of 153
Thread: Bricked ECM
  1. #121
    Jan 2021
    25
    I hope someone hears back as to a root cause. I really want to try HPT shortly. Not for a Dodge though, but for a Ford to start.
  2. #122
    i got a reply back ad this was it
    "Hello,
    The engineers provided a Fix for this in the latest BETA version. Our apologies for the inconvenience."
    2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
    2008 F-350 03 5.9
    Fumminstuning.com
  3. #123
    Jan 2020
    Iowa
    64
    Quote Originally Posted by guy-ffc View Post
    "Hello,
    I tried the BETA and it didn't work. I tried it on the old ECM (recommendation from support) when I got the write error. I am not confident in trying it on my new ECM. If they provided me a way to full flash the ECM if the write failed or some kind of recovery option, then it wouldn't be a problem. Without a restore/recovery option then there is no way.
    2008 Dodge Cummins 6.7 - 2nd Gen Swap S467.7/83/1.0, No Grid Heater, Banks Intake, BD Flowmax LP, G56 w/SB Clutch.
  4. #124
    Quote Originally Posted by dieseldude View Post
    i don't blame you I feel super lucky mine got going again
    2008 F-350 03 5.9
    Fumminstuning.com
  5. #125
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    I made 34 tune changes and flashes over the last year to my truck. Only the last one failed and bricked my ECM. The last one I made after updating to VCM Editor 4.8.7. I didn't think anything of it at the time other than trying to get it to work. Now with others having similar issues, it looks like there is something different in the latest release that is suspect. I even sent my ECM to support to test and try to flash it. They were unsuccessful and never gave me a root cause for the failure. Without knowing the "why", I won't brick another ECM that cost me $1300.
    I understand...
  6. #126
    Banned
    Jan 2018
    Everywhere
    1,772
    So this is how messed up my trucks become since the original ECM got bricked, the wireless ignition module does not send the secret key for the skim to the ECM anymore but the truck still starts and runs. Wanted to start with a fresh tune file in EFILive, forgot to set the VIN in the tune file before flashing it in, still starts and runs.
  7. #127
    what ECU is in your truck. i use Flex for a lot for ECU recovery and cloning.
  8. #128
    Banned
    Jan 2018
    Everywhere
    1,772
    Same ECM that?s in every 2010-2012, the CM2200.
  9. #129
    okay in the ecu list for dimsport i see cm2100 this is why i asked. they do not show a cm2200 but doesn't mean they don't support it
  10. #130
    Banned
    Jan 2018
    Everywhere
    1,772
    CM2100 is the 07.5-09 6.7. I got my Cummins hardware now, whenever I get time I?ll be seeing if I can get my original ECM recovered with it.
  11. #131
  12. #132
    Jan 2020
    9
    Seems like I am having the same issue on a 2003 cummins. I tuned it yesterday with no issue and then made changes and tried to flash again this morning and it failed halfway through and will not communicate with the ecm anymore. Has anyone found a way to fix this or am I going to have to buy a new ecm?
  13. #133
    Dec 2019
    24
    What is the actual error saying.
  14. #134
    Jan 2020
    9
    I dont remember the specific error but it failed half way through a flash and then when I re-tried it would try to flash but never acually started. It failed to even recognize the ecm and start the process. I then tried to read the ecm which I know technically doesnt work on an 03 but once again all I got was a detect protocol failed message. after messing around with a few things for 30 min or better I decided to disconnect the batteries and go home for the night and maybe give it one more shot the next day. To my suprise everything worked as it should when I reconnected the batteries the next morning and tried it again. The file flashed with success and there have been no issues since.
  15. #135
    Banned
    Jan 2018
    Everywhere
    1,772
    Got lucky
  16. #136
    Feb 2019
    5
    Quote Originally Posted by Jim P View Post
    Got lucky
    Add another 2005 to the bricked pile. I've been going back and forth with support for a couple of months on a project truck that I was able to write to multiple times and then it just stopped being able to write. Had to setup a bench harness and can't read anything just get an error.
    This is a stand alone setup and being a 2005 doesn't look like EFI Live is an option for me. Does anyone have a suggestion on what I can go to as an option? I have a new ECU but don't want to fry another one. Just need this dang motor to work stand alone with an external fuel pump.
  17. #137
    Jun 2018
    Albuquerque New Mexico
    465
    Has anyone flashed anything newer? Like 2017 and up? I was happy about the new dodge support but i'm not looking forward to a bricked ECM.
  18. #138
    Feb 2016
    Champaign, IL
    34
    Was everyone using the MVPI2 or the original MVPI interface?
    2003 Ram 2500 QC LB 4x4 48RE 5.9HO 87000 miles all stock
  19. #139
    Oct 2019
    Cm2350 works fine. I Bricked a cm2450 ($3k ecm nationwide backordered) Heard from others more than 20 cm2450s being bricked by hp as well.
  20. #140
    Banned
    Jan 2018
    Everywhere
    1,772
    Old thread to bring to life but it?s due to bad software build. I haven?t bricked a single cm2350 or cm2450 but long time ago had multiple cm2200?s brick on me including my own truck and it really did a number on my truck, never been right since. I was able to recover my original ecm and it?s a backup now for a just in case.
