Results 1 to 15 of 15
Thread: 2007 pontiac grand prix 3.8 vats delete help
    I have a 2007 pontiac grand prix 3.8 v6
    Have mpvi2 and need to delete vats badly. Im supposed to move and can't start my car. I did the turn vats off option but car struggles to try to start and when it does its like rough like in limp mode or something and isnt turning on fans. Please help me out.
    Anything ?
    SoCal
    1,588
    VAT's issue will be a flat out no start. Some early will start run for a second and act like the ignition was shut off. If it runs at all no matter how bad you don't have a VAT's issue.
    SoCal
    1,588
    Try this. Ignition off. Disconnect MAF. Key on Engine off for 10 seconds. start car. If it is good you have a MAF issue. Software/wiring/ECM/PCM/false air etc etc.
    This didnt seem to work. It cranks. Then idles for a few seconds then dies
    Im not sure how to attach my tune file to this post
    Got it
    Sep 2010
    FL
    374
    You have to figure out if it stalls because it runs like crap, or because VATS shut it off. If it stalls because it runs bad, you shouldn't have a security light. And if it stalls because of VATS, it should run just fine until it stalls.
    The car runs good if vats isnt involved i know.
    Sep 2010
    FL
    374
    Did you get your car to run? If not, I can delete VATS for you.
    No, when i tried flashing with vats selected to off, it would turn over actually, but would either run really badly(limp mode/no fans etc) or not start period. So now i have it at a mechanic shop and they are having trouble with it also. The anti theft module made for these cars is just a piece of garbage and so is that whole system. Iv spent at least 1200$ because of it and still not running..
    It would run and stall quickly
    Sep 2010
    FL
    374
    I've done 2007 Grand Prix PCMs before successfully. If you want to give it a shot, contact me.
    Steve
    Feb 2019
    3
    Quote Originally Posted by pontisteve View Post
    Steve
    I've got a similar vats issue on a 2007 grand prix based engine swap it runs for a few seconds then it kills injector pulse and won't restart till the battery is disconnected for 5 minutes
    I'd appreciate any help you can provide
    Sep 2010
    FL
    374
    Quote Originally Posted by Joedirt View Post
    Having spark, but no injector pulse, is because of VATS. Also, VATS typically lets a car start, run for about 2 seconds, and die. Over and over again. Plus, some sort of security light should come on. Further proof it's VATS.
    HPT's software doesn't work right for this in my experience, so don't waste credits.
    I can do it using different software if you want. Email me.
