For the first setup after cam swap from 2013 5.7 vvt mds to 6.4 vvt non mds I wonder what MBT to use.
The two engines seems to be mechanicly identical .
The lift and the lsa are different ( 115 to 121 ), so I took the values from the 6.4 for the vvt.
Now the rpm range from the 6.4 ist bigger, so I use the row settings on the mbt table.
Would it makes more sense to copy the values over and not expand the table with own values - ?
