Results 1 to 13 of 13
Thread: FIC +30% LT4 injector tuning
    Dec 2020
    10
    I just bought a set of these and looking for some help with setting up the necessary tables to be able to start up and drive. It's a 18 ZL1 M6 w/ 38% fuel lobe cam, ported heads, Cordes aux fuel system 2" headers, ported stock blower, 2.3 upper and 9.1 lower pulley. Any help is appreciated
    Dec 2015
    Miami,Fl.
    292
    Quote Originally Posted by sickss228 View Post
    I thought they came with the basic injector data?
    2023 Ford Maverick 2.0T AWD
    Dec 2020
    10
    Quote Originally Posted by HeavyChevy305 View Post
    I'm not sure what they come with. The guy I bought them from just said they usually come with injector data, I was assuming flow rates etc... I was wanting to see what tables had to be modified so I will be able to drive it down to my tuner. I remember reading somewhere it was only a couple tables that needed changing, I searched on here with no luck though so it was probably a different forum. Any help is appreciated!
    Jan 2020
    42
    Injector flow data and parameters must be know and input when the new injectors are installed. It can't be inferred or "tuned in." The manufacturer is the only source for this data.
    https://cartrainingonline.com/courses/gm/
    Check out Greg Banish's GM Gen 5 Tuning Training. Covered in detail there. A bit of an investment, but well worth the price for the information provided.
    Jan 2020
    42
    https://www.lingenfelter.com/Calibra...730126927.html
    This is data specific to Lingenfelter DI injectors, not FIC injectors, but it gives you an idea of which tables get modified. I suppose "a couple" is subjective to who is interpreting it...
    Dec 2020
    10
    Quote Originally Posted by pisces_0 View Post
    Great thanks alot! I wasnt sure if they came with all that data, that makes me feel better if they actually tell you what tables to change. I am new at this and dont want to mess anything up. I am going to look at that genV tuning link. I just bought his book on tuning also.
    Mar 2006
    Detroit
    1,033
    @pisces_0 thanks for the plug. DI injector swaps are just not as straight forward as PFI injector changes right now. Most resellers don't even understand how a DI injector is characterized in the calibration, let alone have the equipment to generate that data at the correct working pressure.
    I have seen the best results with switching to a known solution (like the factory LT4 injector going into an LT1) where the spray targeting at least remains constant. If that isn't enough extra fuel (ASSuming the HPFP can keep up), an auxiliary PFI system certainly has its merits. Replacement DI injectors are EXPENSIVE, and are not guaranteed to drive nice (or pass emissions if that's your thing), where a properly applied add-on system keeps the "normal" driving consistent and has some fringe benefits like intake valve/port cleaning.
    Dec 2020
    10
    Quote Originally Posted by eficalibrator View Post
    Thanks for the reply Greg, I have been reading your books and watching your vids trying to learn as much as I can. I got a great deal on the injectors so I jumped on it. I was under the impression that the FIC injectors use the stock tips to retain the stock spray pattern and drivability? I was looking at some of the PFI setups out there but they are alot more money than the injectors and there are not many reviews on them out there. Thanks again for the help!
    Aug 2020
    Petersham, MA
    134
    Did you try reaching out to FIC for this data?
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ
    Mar 2006
    Detroit
    1,033
    Just catching up on some older conversations here...
    NO, just because one keeps the stock tip, does NOT mean that the in-cylinder fuel distribution is the same. By defninition, if they increase the flow rate of the injector, more fuel is going somewhere. They just can't tell you where because they don't have the same tools as the OEM to characterize both the dynamic flow and the targeting/penetration into the combustion chamber. Sorry, not enough...
    Advanced Tuner lt1z350's Avatar
    Mar 2014
    Dandridge, TN
    560
    If still needed any data I have it. They work excellent been on my car 2 years now. Car drives great with big cam and tons of work done.
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by lt1z350 View Post
    I'd love a copy
    Mar 2014
    Dandridge, TN
    560
    pm or email me and can get it over to you
    First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
    2013 cadillac ats 2.0t Big turbo-gone
    2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
    2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
