What's the best approach to fixing this issue? I know I can scale IFR and every airflow and airmass table, but that sounds like a pain in the rear and seems kind of rigged. Is there is custom operating system or newer ECM I could use? I read that the older custom operating system has a higher limit, but are there custom operating systems for version 3.4?
I thought 08 and newer had higher limits, but my buddy's 08 tune is the same as mine. Maybe that only applies to injector flow rate. It looks like 2010 has higher MAF limits. Can I switch to a 2010 ECM or are there issues associated with that?
