Results 1 to 4 of 4
Thread: 2015 Challenger Scat TSP Stg 4 Cam
    Dec 2007
    13
    Keep getting "Crank-Cam Correlation and Exhaust Cam Actuator Circuit" (P0013 & P0016), after install... Is a relearn required after the install? or just needs codes canceled through tuning cause of the lock out kit? Car runs pretty good now just dont want to spend the time fine tuning then have to go back and re do everything cause something is wrong here. any help is appreciated .
    2015 DODGE CHALLENGER 6.4 - ECM ONLY - REV. 2.hpt
    Jun 2007
    Finland, Europe
    548
    Well, at least P0016 is direct result of cam not being adjustable anymore.
    I would just disable those codes.
    Dec 2007
    13
    tried the cam crank relearn today and failed test.. im trying to get some reassurance that it is cause of the lock out kit. been searching but havent found anything yet.
    Nov 2009
    All Around
    3,149
    if you cam is locked, you will need to turn codes off and have the solenoids disabled
