I have attatched 2 log runs and the tune for those runs, both have the same tune for the logs. First run PE commands good and then I shut the vehicle off a couple of times then I take truck the next day to the store and it will not command PE. I posted earlier about it and it seems to be around the 3rd key cycle that it does this but maybe not exactly. It has happened to me around 5 times now. But as soon as I reload the tune all is good and PE commands again and I get about 3 cycles out of the key and then it does it again until I reload the tune. I'm sure I am doing something wrong, I just don't know what it is.
Any help is appreciated thank you.
Truck Specs
2012 Silverado e38 ecm
7875 VS turbo 5.3 stock everything else current tune MAF only open loop
zr1 map sensor
