Results 1 to 3 of 3
Thread: good running tune but any tips always help
    Nov 2020
    11
    i have my 08 chevy Silverado here im running open loop. i was able to find a good ve chart. from a 2011 chevy Silverado. my truck really likes at wot but down low i dont have any torq down low off the line. i know im still a little fat on the fuel trims. but better rich than lean here is my 2 of my logs. i finally was able to get it to start up great on the cold starts by lowering the timing in cranking down to 5 degrees working my way up. it fires up perfectly ignore the Speedo twitching. i believe its the tcm. that's bad. i keep getting hard shift. from 1st to second i have the new tcm coming this week. and the afr goes a little wonky but it pretty close. i have a pinhole exhaust leak.Attachment 106808Attachment 106809Attachment 106810Attachment 106808Attachment 106809Attachment 106810
    405
    2,322
    Open loop doesn't use fuel trims.
    13,564
    You set the MAF codes to no error reported so it's not really in speed density if it can't fail the MAF sensor.
    And if you are commanding 13.35 but setting low 12's in the wideband you have a major issue there. It should command 12's and be 12's with the wideband.
    What injectors are installed? They don't seem to be scaled right if you had the max out the flow rate at 63.5 lb/hr well before 58psi of fuel pressure.
