Results 1 to 4 of 4
Thread: E38 lean tip in/ stumble. Helppppp
    Aug 2020
    chattanooga tn
    3
    2012 SILVERADO 4.8L, e38, 78/75 TURBO, DEKA 80'S 93 OCTANE. SD/ CLOSED LOOP.
    anytime i punch the pedal or come off 0 tps i get a bad lean stumble. Any help?
    Nov 2006
    2,808
    A log with a wideband would help. Typically it is a spot too low right off idle in the VE table that you move through too fast for the wideband to see.
    Tuner at PCMofnc.com
    Aug 2020
    chattanooga tn
    3
    Quote Originally Posted by colehunt View Post
    i have both tune file and logs but cant seem to figure out how to post them.
    Aug 2020
    chattanooga tn
    3
    here is some logs, at idle, in drive, and pull from 2nd. i dont think its the VE table because my fueling is fine and long as there is no sudden throttle movement threw those cells. Does my dynamic airflow enable/ disable look correct? do the coefficients need to be zero'd? Also, Fast torque exit be enabled?
