Results 1 to 8 of 8
Thread: weird o2 behavior
    weird o2 behavior
    Guys we are dealing with something evil in the car. $we changed the camshaft. stage 3 pd from stage 2 to a friend's car. Brian tooley racing. it happens that randomly one of the 2 02 sensors reads 52 mv while the other is 450ish. it could be either one. sometime from left bank sometime right
    Also when this happens, the car pulls fuel. we see -20 ltft even when the wideband reads the correct afr. of course when it starts to pull the car becomes lean. Very weird behavior. it happens randomly
    any idea?
    Australia
    1,981
    if its pegging at 450mv then it sounds like its loosing connection like wiring issue to the 02's
    No I meant that when this problem happens,one o2 sensor is around 450 but not steady,which is stoich but the other one reads a total different value like 50ish or 60ish. Something like that and it could be either one. Sometimes it's the bank 1 and sometimes the bank 2
    Australia
    1,981
    u will have to post up a log of the issue, do u have wideband ? what does that read
    If in open loop the wideband reads perfect 14,7 once in closed,it reads 17.5 but the fuel trims keep pulling
    Australia
    1,981
    is your wideband analogue 0-5v ? sounds like WB may be off and could have a ground offset if its analogue, if 02's are CL and cycling as they do they should be true
    it's an Aem canbus
    Australia
    1,981
    not sure would have to see a log of it too have any idea of something going on
