Results 1 to 7 of 7
Thread: should i start with 02 fbody or 04 gto tune, swap to speed density os?
    Feb 2018
    NC
    53
    Would like some opinions on if i should start with 02 fbody or 04 gto tune, and/or swap to speed density os for my 1980 z28 start up tune and what to change?
    Has 2006 L33 5.3l punched out to 5.7
    243 truck heads
    LS6 Intake/injectors
    TBC
    1 7/8 long tubes
    flat top pistons
    summit 8707 Stage 2 Pro LS Cam. 226/238 113+3, .600/.600 Lift
    Dec 2008
    on the Dyno
    1,825
    Two different PCM's. 04 GTO uses a P59. 02 Camaro uses a P01. Use one or the other depending on which hardware you have.
    Located in Central Kentucky
    ShorTuning
    Feb 2018
    NC
    53
    will most likely go with the fbody 411 since i am also converting the 4th gen abs to work on my 2nd gen.
    2,742
    If you had the choice a 02 F body would be better IMHO
    Tuner at PCMofnc.com
    Feb 2018
    NC
    53
    should i keep the MAF or switch to speed density os? i have been reading mixed opinions
    13,565
    Keeping both isn't a problem. You won't make more power than the MAF can handle.
    Many just choose speed density for cleaner intake systems and because they prefer to tune it in speed density.
    2,742
    Quote Originally Posted by It Will Run.Maybe View Post
    That cam is on the edge of what I would do with a MAF. SD will give a better result with anything more than a mild cam. Reversion will effect MAF readings at low load/RPM
