Purchased a 2013 gmc 1500 that was tuned with hptune , how can you remove tune and put back stock
You would require the stock tune for that truck but you obviously do not have that.
The best you can do is find a stock tune in the tune repository for the 2013 silverado/sierra. Then you can COPY data over and make it stock again. I put emphasis on the copy because you never write a tune that isn't yours into your computer.
There is not just one stock tune for a 2013 Silverado. Any stock file you look at you need to make sure all the segment numbers match even if you are doing a copy.
