Originally Posted by
K44
Roush's tune doesn't change the voltage or pressure modifiers. It also sets flow rate high at 60 lb/hr when Fords pressure modifier sets the LU47 at 56 lb/hr.
Ford's multiplier is at 55 PSI. If Roush uses 58 would it then match?
What is the actual coyote fuel pressure? If Roush's numbers worked I wouldn't be asking these questions.
I had a calibrated MAF, changed to LU47's used Roush injector numbers and ended up with an avg 6% pulling of fuel. Some places it is over 10%. Before the change it was avg 2% pulling fuel.
I don't think Roush is using LU47's
What really confuses me is the 2014 Roush tune uses 100 lb/hr injector data and when I use that data I get the same 6% avg pulling of fuel.
HELP!
Please teach me to fish.
