Results 1 to 17 of 17
Thread: No Start
    Mar 2018
    South West
    115
    No Start
    2004 6.0 4l60e cammed dbc pcm originally on a 2002 yukon 5.3 dbw. Tried changing os system to speed density and after copied a dbc tune to my file and starts but doesnt run unless i add starting fluid is there somthing im missing ?
    13,565
    Get your IAT working.
    You didn't put the tune into speed density if the MAF is removed. Set the MAF fail high to 0hz and set all 3 MAF dtc's to MIL on first error with the SES box unchecked.
    Under system you need to set the VATS from serial to none.
    Change the cylinder volume to a 6.0 engine size. Make sure the injector data is correct for the injectors this engine is running too. Also fuel pressure must be 58psi.
    Mar 2018
    South West
    115
    Thanks idk what i did but i changed everything you said and now it starts but barley just needs to be tuned Tanks !!!
    Mar 2018
    South West
    115
    question now it doesn't stay running any ideas
    13,565
    Your IAT still isn't working.
    How's your battery voltage?
    Any trouble codes?
    Mar 2018
    South West
    115
    Yes waiting for iat to come in and no codes alternator wasn't plug in
    Sep 2020
    6
    Where do you set the fuel pressure at???
    Chancellor B Rowland
    Mar 2018
    South West
    115
    Update runs but not good do you guys see anything
    13,565
    What is your fuel pressure?
    Is the exhaust 100% complete? Or atleast have a large amount of the exhaust complete after the o2 sensors?
    The log shows that it's super lean when you rev the engine and hold it there.
    Post the most recent version of the tune file.
    Mar 2018
    South West
    115
    yes it is i think maybe a small exhuast leak but anyways what do you think is causing it to go lean heres my tune file and my orginal tune. I started off by copying a similiar 6.0 tune becuase the pcm i had was on a dbw 5.3 and from there jusy change injector size and speed density stuff
    Mar 2018
    South West
    115
    files
    13,565
    I tried to tell you what the settings need to be for speed density but the tune still does not have them right.
    Set the MAF fail high to 0hz and the codes P0101, 102 and 103 to MIL on first error.
    What happened to your injector data and that VE table? The VE table is like 100% over inflated.
    Again, what is your fuel pressure? You must be running ~58psi for these calibrations.
    Also if you are not running a flex fuel sensor you need to disable the flex fuel feature.
    Mar 2018
    South West
    115
    Got it done and i added fuel becuase it was to lean and also injector size grew becuase of ls2 intake and also fuel pressure is at 58-60
    Mar 2018
    South West
    115
    There you go runs a lot better like a lot
    13,565
    Is the LS2 injector data right?
    There should be no reason that you would need to increase the VE table that much just to make it run.
    Mar 2018
    South West
    115
    No i put the ve table back and changed the mass fail and dtc on first and also turn off flex.
    13,565
    Then fix all that too. Injector data must be correct.
    I figured some of this was a given.
