Results 1 to 4 of 4
Thread: Gpec2?
    Gpec2?
    What is the maximum boost a GPEC2 ECU can read. I've read it will only recognise up to 200 kpa using a neon SRT4 map sensor. I'm curious to know if this is true or not?
    Oct 2005
    baton rouge la
    411
    Im pretty sure with the correct MAP sensor it can go over that. I know GPEC2A will go to at least 300kpa
    Jun 2010
    293
    in my experience, it hits a limit at 200kpa, u need to setup on diagnostics to a max of 198kpa or something like that, it will not hit the limiter anymore but it will not read more than 200kpa, it was on a 2013 6.4l pcm, on a jk hellcat swap... in my cause i was at 210-220 kpa
    Quote Originally Posted by castorjames View Post
    Thanks for the response, if I change the settings in the diagnostics section to your recommended settings, can I log greater then 200kpa in HPTuners? I have both a 2bar & 3bar map. Just trying to ensure I can tune properly in the higher boost range. I have a 13 GPEC2 PCM, running a transplanted 6.4 with twin 72mm turbos.
