Hi,
I am trying to setup a 2011 Mustang 5.0 for Flex Fuel. It has an Edelbrock Stage 2 Supercharger (Eaton TVS-2300 rotors) with DW 88lb injectors. Stock fuel pump.
Just a few questions... I looked at a few different Flex Fuel tunes here on the forums to get most of the tables populated.
I couldn't find any Coyote tunes that were specifically described as both boosted and Flex Fuel.. so I'm nervous what do with the spark, so I left stock for now.
Please if you guys with experience don't mind:
1) do you see anything I'm missing other than spark?
2) anything need to be changed?
3) can you advise values for borderline and MBT spark tables for FFV Modifier and Multipler tables?
It seems like Coyote's don't have a MAP sensor (I'm coming from GM and Dodge world) so i didn't expect to need a boost gauge. So right now, I'm not sure of the boost on this kit, I'm sure its somewhere less than 9psi.
Do you guys believe the DW 88lb injectors will be able to keep up with E85, considering stock fuel pump and this fairly mild level of boost?
Thanks so much for your help. Slowly learning this first time (for me) Ford!
