Results 1 to 8 of 8
Thread: Gen IV 6.0/6L90e LSA supercharger tune file
    Nov 2019
    21
    Hi everyone,
    I looked through the repository and found no supercharged 6.0 files at all.
    Does anyone have a tune file I can use as a starting point just to get the motor running for the first time?
    2010 LY6 6.0/6L90e
    823 rec port heads
    Cam 234/247 113 +3.5 .625/.605 Lift
    60lb injectors
    9.6:1 compression
    13,564
    To get you going you probably just need to put in the injector data you got with the injectors and change the MAP sensor linear and offset settings for the 3 bar MAP sensor on the LSA blower.
    Disable VVT by settings the camshaft from one to none in the variable camshaft tab.
    It should start if you do that. It may not run super good but it should start with that much of the tune is changed.
    Nov 2019
    21
    Not gonna lie I’m a total noob with tuning. I have a guy that does my harness builds and basic unlocking and tuning for standalone setups but he doesn’t have anything for a supercharger. Once the motor is in a vehicle it’ll get tuned professionally on a dyno. But until then I need to test run it on my stand and I wouldn’t want this new build to go bang because it’s got a tune that’s waaaay off ��
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    If it just needs to start, keep it out of boost and it doesn't need a supercharger tune
    Aug 2009
    Calibrating
    3,373
    I’m going to get him lined out
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Nov 2019
    21
    Quote Originally Posted by 383_Stroker View Post
    Nov 2019
    21
    Quote Originally Posted by Ben Charles View Post
    Yea buddy! �� ��
    Jun 2014
    Boulder, CO
    202
    You'll need the correct injector flow data and fuel pressure (constant or referenced to MAP) before it would likely even start. My 6.2L E-Force s/c build uses "shorty" Siemens/Continental 60lb @ 3 bar injectors. DM me if you'd like to look at my tune. My engine's displacement, cam, and s/c are different than yours but may be useful at least for comparisons.
