Results 1 to 7 of 7
Thread: 2007 Silverado 4.8 will not go into closed loop unless vlom solenoids are plugged in
    Jan 2019
    6
    Cant get truck into closed loop with hptuners DOD delete unless you plug in vlom plate
    13,565
    4.8's don't have AFM/DoD.
    Did you disable all the AFM related trouble codes if this is a 5.3?
    Jan 2019
    6
    5.3 sorry
    i only disabled DOD
    Jan 2019
    6
    I did clear all trouble codes before i down loaded tune
    13,565
    There are trouble codes related to the VLOM, so you will want to disable all those codes if you removed the factory VLOM.
    Jan 2019
    6
    I'll go at it again and post. Thank you
    Nov 2006
    2,741
    Setting all the DOD solenoid codes to 3 no error reporting will fix this.
    Tuner at PCMofnc.com
