-Stock Flywheel
-93 octane fuel
-FIC1000cc injectors
-T56 6-speed car
-Mcleod RXT Twin Disk
My issues
-Cold Start and idle until warm up. (Main issue)
-Idle fluctuation (300rpm to 1300rpm) out of gear while coasting. Idle normalizes as soon as I'm stopped.
Tune / Recent log attached.
The log I had started prior to trying to fire the car for the first time. You can see I started the car several times, while using throttle to try to keep her alive. Slowly it'll stay fired for longer and longer until it no longer dies.
Alright so, I've managed to slowly read up stickies and HP Tuners guides and correct the start up issue, as well as an issue I was having with the O2 sensors not responding quick enough.
I have attached my current tune, and latest log. Hopefully someone can provide some input!
I have tried the following and have not been able to correct the rolling idle surge.
03-21-21
ECM12645 Idle Underspeed
Changed values to match Factory Z06 values
ECM12080 Target Idle match Factory z06 values
--Still idle surges--
ECM12130 throttle Cracker
Multiply entire table by 0.85
--Made the surge worse
ECM12130 throttle cracker
Mutiply original Value by 1.10
--No change
03-23-21
ECM12084 Idle Airflow
Increase by 10% at 176f and up
--Seemed worse
ECM12084 Idle airflow
Decrease all by 10%
--no change
Match factory z06 values
--Super worse
