Results 1 to 4 of 4
Thread: 2011 Sierra 4l80 Swap
    2011 Sierra 4.8 originally was 4l60 and just swapped over to 4l80. It is rewired, flash 80e file off a van and it is stuck in 2nd gear/limp mode however speedometer works fine. Flash stock 4l60 tcm file back in, trans goes back to normal however speedometer only gets to 9mph then falls to 0 (OSS signal also drops to 0) and trans wont shift. Anyone ran into this issue before? Thanks.
    7,603
    Are you able to post the before and after tune files?
    If you used the common 2008 Express van file (early), that's why it doesn't work with a 2011 ECM (late).
    i feel it's an issue with the wiring or something like that. put an early e38 off a 2008 suburban and same thing, t42 with 80e OS shows 2nd gear. Flash 60e tune to T42, goes back into 1st gear but speedo reaches 10-11 mph and just instantly dies. Speedo works perfectly fine with the t42 and 80e OS but stuck in 2nd
    7,603
    You feel it's an issue with the wiring and the only info you can give is "it is rewired"? So this is just like a blog post where you talk about things going on in your life, or you want to post some actual information - documents, diagrams, files - other people can look at to try to spot a problem?
