Results 1 to 10 of 10
Thread: Wierd power drop over 5800 rpm
    Hey guys.
    For some reason i have been unable to figure it out why my power drops in a weird shape over 5800 rpm on ZL1 LSA camaro. Is not boost or any ignition source. I have tried raising torque management tables with no changes so far. Fuel is very stable and we dont have VTC so i dont know what else cuold it be.
    Here is the dyno chart, log and tune.
    Thanks alot.
    It looks to me like you have a restriction somewhere that is limiting air/exhaust flow. If you notice that in the first run your power seems to peak later.
    Owner/Tuner@Evolution Automotive Performance
    Lincoln, Ne
    Quote Originally Posted by Evo8john View Post
    I was thinking the same, but now it has long tube with 3 inch colector, JLT Cai and 3 inch exhaust. OEM TB.......dont know.
    Jun 2014
    Boulder, CO
    204
    I see the power drop on the dyno sheet but not in the log you posted. Maybe tire slip on the chassis dyno? With 27* of ignition advance at 1.22 g/cyl and no KR, you must be running some good gas!
    SoCal
    1,573
    Can't really get into checking right now but look at your gear/tire/trans ratio compared to dyno speed and you should see/not see a difference in mph at slip point.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Quote Originally Posted by pannetron View Post
    If you take a piece of paper and line it up to RPM and Speed on the log, you will see it changes at 5800rpm, matches up with the change in torque reported from the dyno.
    ZL1 Wheels/Tires
    Jun 2014
    Boulder, CO
    204
    I looked more closely and I do see a small dip in the MAF reading starting at 5775 RPM.
    Mar 2012
    Detroit, MI
    1,320
    I use the paper edge trick all the time, even at work, or anything with a plot line. People look at me funny, but it works!
    ZL1 Wheels/Tires
    97 oct and meth kit.
    Ok...will do. Thanks.
