Results 1 to 8 of 8
Thread: iPhone 12 Pro + XGPS160 + GoPro Hero 5 black unstable connection and no GPS
    Feb 2021
    5
    Hello,
    I've been using Track addict and Race render for quite some time, you can see my videos here > https://www.youtube.com/user/mario206rc/videos
    Till last track day, I was using iPhone 6 with XGPS160 and GoPro Hero 5 black and there were small issues with GoPro connection which sometimes broke, and with XGPS160 which sometimes lost connection which was weird because in SkyPro application there was always good connection to many satellites.
    Lately I purchased iPhone 12 Pro, thought that this would solve my problems, but problems got 10x worse! GPS signal with XGPS160 is almost always not available and searching, and when I switch it to internal iPhone GPS, situation is even worse. Also, GoPro connection is lost every few minutes and then I have to stop logging and turn off and turn on GoPro to make a new connection with TrackAddict.
    So long story short - TrackAddict is now useless since I can't record whole lap without signal being lost or GoPro being disconnected.
    Do you have solution to this problem? I'm using paid version of your iPhone TracAddict and RaceRender application.
    Mario
    Feb 2021
    5
    No answer after more than 1 week? What kind of support is that?
    Feb 2021
    UK
    12
    Not sure if this helps, but I have an iPhone 12 Pro, and usually link it to my BMW 5 Series for music etc. via a lightning to USB generic type cable (certified for data use). Which all worked fine with an iPhone 8 Plus.
    What I found, was that the old lightning cable no longer works, you must use the new one supplied with the iPhone 12 Pro, plus a converter.
    In my case it was a standard USB in the car to USB-C Female, and then use the new cable (EU has USB-C to Lightning because of the EU laws), and all the data connectivity was restored again.
    Feb 2021
    5
    Jsolman, my GoPro is connected via WiFi and XGPS160 via Bluetooth, no physical connection to anything. It's used in an old Audi S3 8P from 2008. The only other BT thing connected to my phone is BT from Audi, but disconnecting that doesn't help with my problem
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Quote Originally Posted by Mario_S3 View Post
    emailing support, would get a faster response from support. Although support often replies to issues here, it is in fact an end user forum, not a support forum.
    always email support for a direct response
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Feb 2021
    5
    Quote Originally Posted by mbray01 View Post
    I didn't know that - but looks like I'm the only one with that problem
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    I bought a XGPS160 and after 3 full days of trying to acquire signal, i said heck with this, sent it back! So odds are, it's the XGPS160, it sounds pretty flaky, even when it does work, accuracy is not good.
    Now I use this, and it's SOOOO GOOOD. Super accurate, Super Cheap, $30 total? Only problem, it currently only works with Android with TrackAddict. Other program that use BLE, which then works with IOS. 10hz updates, super accurate. I put one in every car.
    https://github.com/renatobo/bonogps
    ZL1 Wheels/Tires
    Feb 2021
    5
    Yes, XGPS160 is very super slow, it takes up to 5 minutes to get position from many sattelites. But once it's connected it should work ok. But it doesn't apparently when connected to Trackaddict and new iPhone 12 pro.
