Attached a log file and tune file I was hoping someone could glance at. This is an unopened '06 LS2 E40 from a tbss. The tune file is completely untouched aside from vats removal and Ive verified that from a couple stock tunes from the repository. Fuel trims max out immediately and when revved up to 3k the ltfts stay high, which should indicate a fuel delivery issue not a vac leak? With the first pump customer provided I was only getting 50 psi. Ive since changed the pump now getting 60 psi, no change. MAF is currently failed. Any help is appreciated thanks
