What type of connector is the Pro Link to MPVI2 module? It looks like a Thunderbolt 2/mini-DP connector.
I want to get a 90 degree adapter.
https://www.hptuners.com/product/pro-feature-for-mpvi2/
Pro Feature Set - HPTnet Activation (MPVI2 display port)
I think it's Mini-Display Port. But be careful, not sure what would happen if you plugged in other cables to it.
Mini-DisplayPort 90 degree adapter, they have 3 angles to choose from, let us know if you try it!:
https://www.amazon.com/Duttek-Displa...xpY2s9dHJ1ZQ==
2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
ZL1 Wheels/Tires
I am just going to do an OBDII extension cable. It is cheaper.
I found an OBDII splitter that I bought at some point.
I am going to use that to connect the Pro Link.
