Results 1 to 20 of 37
Thread: 6.0L SOTF (Shift on the Fly) Stock file W/OS Mod (File inside)
    Here's a 6.0 file clean stock file that was uploaded to the forum awhile back.
    I applied the Shift on the fly OS modification
    This is first true SOTF method that has made it to market for the 6.0L
    With individual slots (up to 5) timing, pedal to fuel, max torque to fuel, EBP, ICP, torque model etc
    Use as a reference only for stock values.
    To apply SOTF OS Mod your PCM your file/pcm must be on the latest ford flash.
    Click OS tab and follow on screen instructions
    Attached file can be opened on the latest beta
    2008 J2 F-350 CCSB
    TCM side of things still isnt SOTF capable but you can manipulate the torque model per slot to get your desired differences per slot and or tune.
    2008 J2 F-350 CCSB
    Banned
    Jan 2020
    Arlington WA
    250
    what did you use to control it? intake air temp?
    Quote Originally Posted by Powerstrokecustoms View Post
    Steering wheel controls its a custom OS
    2008 J2 F-350 CCSB
    Apr 2021
    10
    What combination of buttons is used for the slots? Does the cruise control still work?
    Quote Originally Posted by WFMCNALLY86 View Post
    Ditto?
    When was this released? Where is the info.
    Its been out for a bit now. 5 slots is only available on 2005+ the 03/04 are only 3 slots.
    Jul 2018
    9
    Is there a way to look up latest cal by vin for Ford like with GM? Or is there a OS compatibility list for the SOTF tuning that you know of? There is hardly anything on the forums about this and I have a 6.0 here I want to test this on. 2003 model year with the 448k pcm. I just "updated" pcm with FJDS and it claims it installed latest server version but the OS mod isn't available in the stock tune read. I did download the attached file from this thread and browsed around it. Now just need one I can actually play with to flash on a truck. Thanks in advance guys!
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    464
    When I try to apply the SOTF modification I followed the on screen prompt.
    When I go to write entire it says I don?t have a license for it. When I have already flashed the truck numerous times without the os mod. Any ideas?
    Jul 2020
    How do I switch the tunes on this setup?
    Is there any more info for the switching steps? I would love to try this.
    Jun 2012
    warrenton va
    464
    would be awesome for some questions to be answered?
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Jun 2012
    warrenton va
    464
    alright guys i have figured this out and it is working on my 03 6.0 Excursion!
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Jun 2012
    warrenton va
    464
    Things I have noticed.. it is a non-inferred strategy.. so make sure your MAF is scaled correctly. Me having a no limit 5? intake I had to scale my MAF.
    Your torque tables needs to be pretty good/accurate. Transmission doesn?t like it when you switch with those torque tables way off or if your trying to run only ?OEM?
    My 03 doesn?t tell me which tune I?m in so I?m unsure on which lights it?s supposed to use for tune verification. I just keep it in my head or if I?m at idle I have my ICP set at different pressures to tell me.
    I will update as I learn!
    Jun 2019
    3
    Care to do a write-up on this?
    Jun 2012
    warrenton va
    464
    Quote Originally Posted by wlong95 View Post
    I can yes. I?ll start one tomorrow. I recently stopped using it because I thought it was causing an issue but it was ended up being my HPOP was weak.
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Jun 2014
    Boise, ID
    68
    I have been doing extensive development on this OS patch since I helped HP test / develope it. Early in testing it was discovered that switching tunes can cause the adaptives to reset when a tune is switched. Clever work with the TCM side can help a lot to reduce the effects of an adaptive reset.
    Getting the torque numbers on the ECM close to changes in power really make it happy so that the pedal position and FMD lines up with the torque number to keep line pressure where it needs to be.
    I keep meaning to do a full write up but keep running out of time.
    Jun 2012
    warrenton va
    464
    Quote Originally Posted by Kadams87 View Post
    I always wondered how to OS patch was applied. what software was used?
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Jun 2014
    Boise, ID
    68
    HPT applies the patch
    Jun 2012
    warrenton va
    464
    hmm thats funny the last time i talked to hpt about the SOTF for the 6.0 he said he didnt knew it existed lol
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
