I was tooling around with scanner and decided to add misfire by cylinder to my channels. Did a log I had some right at start up and in light pedal on 4-5 cylinders with low counts 1-2 hits. There?s no DCT?s and MIL isn?t on plugs and wires are new and I pulled them recently all looked uniform and oil free. When I see them pop up I?m not noticing any hesitation. Obliviously there?s a ecu threshold. With no codes leaves me unsettled, the concept of constant misfiring doesn?t sit well with me. The motor?s got 50K, and I took both of the valve covers off rockers/pushrods/valve spring/etc where good. Any thoughts let me know, since it?s random and subtle on multiple cylinders I?m not think a compression test will yield anything.
