Originally Posted by
GeorgeGG
Hello, i have 2017 V6 3.7 Mustang, car runs perfect under full throttle and runs perfect at high rpm range
Idles perfect but on moderate throttle / load applied at 1500-2500rpm range car gets jerky. AFR is in 14 Range using external wideband
tried a lot of things but could not get rid of this jerky action
i have attached datalog where u can see accelerator pedal is steady and throttle is jumping up and down, so car is getting jerky same time.
at that moment there is no boost, engine is still in vacuum area and throttle is not opened that much.
doe anybody have any pointers with this issue?
attached log with file.
p.s car is running Procharger, upgraded MAP and injectors.
thanks in advance
