Results 1 to 4 of 4
Thread: l83 6l80 swap no start crank
    Jan 2021
    winchester indiana
    66
    ready to pull out what hair i have left... verified all that i know an done all the research i can. she wants so bad to start it just wont.ive had it running before an have drove around the block.it made a couple gear changes an was happy with the results.now she cranks al day an will not run.posted tune an log.begining think i have a fried ecu.
    13,559
    Something is wigging out with the wiring or the computer.
    The MAP sensor is going crazy and the o2 sensors are pegged 1,192mv.
    Jan 2021
    winchester indiana
    66
    so i believe i traced my mistake only way i can get o2 volts down is either plug in 02 backwards or swap with another ecm.this is how i think i have corrupted the files on ecm i had swapped ecm out without disconnecting hp tuners. any insight on this iam new like 4 mo. to all this newer can buss auto tech 2005 an newer.i went an got another ecm 38 bucks shipped. how woukd i go about not frying this one also?
    Jan 2021
    winchester indiana
    66
    i have verified wiring an checked all circuit are correct why ive been stumped
