Need a little help or advice on where to trouble shoot next. Its a 2007 Grand Prix gxp which is all stock besides a k&n filter. I'm having an issue where the car has a noticeable miss when driving in 3rd or 4th. It doesn't throw any codes. While taking a log and monitoring the misfire cycle it will usually have a miss on multiple cylinders. Every cylinder usually has a miss at some point. It's never consistent with which ones are missing. The plugs are brand new as are the spark plug wires. Both o2 sensors have been replaced. New throttle body, gas pedal, map sensor and a new catted downpipe. Fuel pressure is at 57.9 psi, mass air flow seems to be reading normally from what I understand. DOD is disabled. Any help or advice would be appreciated. Thanks.
I will attach the log soon. Thanksgxp misfire 2.hplgxp misfire.hplgxp misfire 3.hpl
Also want to add it’s only when light throttle driving normal. WOT there is no miss or hesitation.
