I have read every single post about techniques to correct fuel trims and following the instructions EXACTLY, I was not getting positive results. I came up with a completely new way to correct the MAF and I'm not sure if I just got lucky or what but I FINALLY got it!!! For best results only log the minimum amount of items and make sure the polling interval is 10ms on PIDs "Mass Airflow", "Short Term Fuel Trim Bank 1", "Short Term Fuel Trim Bank 2", "Mass Airflow Period"
#1 Disable LTFT in the tune
#2 Create a new math and Graph in the VCM Scanner: MAFSTFT.xml and MAF.Table.xml
Use the mass air period values from your tune in the graph - row axis values.
#3 Get a good long log after the car is 100% warmed up and been running for a several minutes. Copy the values that have a good number of hit counts from the graph and "Paste Special-Average" directly to your MAF vs Period table. This took me around 7 applications to get my error less than 1%. Before you flash it, go in to your MAF 2D Chart and make smooth out any parts of the curve that don't look right.
I hope this helps other people as I fought with my fuel trims FOREVER!!! If anyone sees a problem with the information I posted please let me know and I will remove/revise it as to not lead people wrong.
