I?m looking into converting to flex fuel on my 99 LQ4 build. I?m not sure if the PCM will need to be swapped yet or not. My biggest concern at this point is injectors. I?m running stock injectors and already may be in the boat of needing bigger injectors on regular gas so I don?t lose top end.
I know I need bigger injectors for flex fuel but how big? I?m honestly eyeballing some 8.1L Marine injectors that spec at 42lb at 43.5 psi rail pressure. I?m not sure these are enough because the newer flex fuel trucks use 50 lb injectors.
There is so much info I?m not certain WHICH injectors physically fit the truck intake and fuel rail with only the wiring harness needing to be adapted. Any help on this?
