Trying to wrap my head around the next approach to resolving this issue. Tune file attached.
Pulled Tune from Colorado.hpt
Don't really know much about the car. Owner bought it in Colorado (we are at sea level) and is not savvy with cars, just wants to drive it and enjoy it. Has a Whipple on it, and a Halltech CAI, and Meth Injection, runs around 15-17psi, 93 octane.
When it was first brought in, it ran like crap and on the dyno it only made 450whp. We figured it was a mechanical issue so we did the normal diag. Found the air filter was laying the box. Fixed that problem, then it made 550whp. Great, still low and eventually continued to throw the P1101 and P0101. Found that it had a bad hesitation after 5500rpm that felt like spark blowout. We decided to change the plugs with one step colder NGK and gap them down a bit. That seemed to clear up the misfire and now were able to make full pulls and about 600whp. Still low for the mods. We notice on the dyno after 5500rpm it drops off severely. On our logs we see the MAF maxing around 86lb and ~10,500hz. AFR looks great, 11.80 till around redline where it starts to drop into low 11s, maybe even high 10s. We assume this may be due to the meth injection. We tried to get it to go into reduced power mode again, and even after several pulls it never went into that mode, but still had the P1101 code popping up. Then when just driving normal after a few key cycles, it randomly went into reduced power mode and threw both codes again. Clear code, drive normally, comes right back on. Let is sit over night with code cleared, runs great for a long time till it eventually goes back into that mode.
We did notice the meth nozzle installation on the silicon coupler has sealant around it, like jb weld. So we are going to fix that first and try again, but I would like to have the tune looked over and see if there are any changes that should be made? Overall the car runs well, and he is happy with the power, we just need to get this reduced power to go away.
Thanks all
