Results 1 to 14 of 14
Thread: codes P0420-P0430-P0171-P0174 not disable
    Jan 2019
    49
    Hi
    I have friend has camaro 2017 v8, he installed cam shaft and bolt-on, I already disable all codes related for cats or H2o in DTS but still come check engine light
    this codes come P0420-P0430-P0171-P0174
    can help
    May 2003
    South FL
    1,376
    Did you start the car after the mods and before the codes were disabled in the tune? Post your tune if you want help.
    [email protected]
    Owner/GM Calibrator
    Jan 2019
    49
    yes I started the car then check engine light come
    kindly see the attached HPT
    6st.hpt
    May 2003
    South FL
    1,376
    Quote Originally Posted by Rayan_V8 View Post
    6st.hpt
    I was specifically asking if you started the car BEFORE you uploaded the current tune where you said you disabled the codes.
    [email protected]
    Owner/GM Calibrator
    Aug 2016
    943
    Disabling the codes keeps the computer from looking for them in the future but if you already set permanent codes before disabling them..........they are permanent until proven ok.
    Why did you turn off P0171 and P0174? If the motor is lean, you need to fix the problem (vacuum leak) or tune it right (larger intake tube?).
    Jan 2019
    49
    no I started after I uploaded the file
    Jan 2019
    49
    Quote Originally Posted by IARLLC View Post
    yes its large tube (DDR Intake )
    7,731
    I have seen some codes, specifically catalyst codes, that are hard to disable. You turn them off in the tune, write the tune, and somehow the changes don't make it into the ECM. What happens is when you save the file after making changes, the changes are undone and not saved. The file you then write to the car don't have the changes you thought you made.
    Try this. Do only one DTC at a time. Make your changes, close ALL windows in the Editor, then click Save. Close and reopen the file to see if the changes stuck. If they did, do the same for the other DTCs.
    Jan 2019
    49
    thanks for advise, I will try it
    405
    2,337
    I know you are one of the more knowledgeable people here but I've flashed literally thousands of tunes since 2004 in all kinds of GM vehicles and have never had what you describe happen. Permanent codes happen when DTCs are set before they are set to No Error Reported.
    Aug 2016
    943
    You really need to tune the MAF for the larger intake tube. That will probably take care of your P0171 and P0174 and will make it run much better.
    As for the cat codes, if you can put the cats back on and run it until the "permanent codes" clear, then you can disable them and they should stay gone.
    SoCal
    1,571
    So if the monitors have been set and no permanent codes, disabling those codes will result in no permanent codes setting? Learn something new every day. Does that count only on write calibration only or will it also work with write entire?
    405
    2,337
    The only time you need to do a write entire is if you are changing the OS or a parameter that is in the OS Tab. DTCs are in the calibration.
    SoCal
    1,571
    I didn't know that. What I had been doing is if it is the first time I modify the vehicle in any way. Even something small I would do the write entire. Then every change after that I would do the write Calibration. Thank you for the info.
