Results 1 to 12 of 12
Thread: TCC not Lockup at dyno
    Jan 2019
    49
    Hi
    If any one has same this issue? my TCC not lock at dyno only, on the street fully commanded lock
    At dyno, I noticed the tcc line pressure working after 6100 RPM
    I get back street to test and back to dyno, the first run gain 40 hp, after that the TCC come unlocked even the curve lost 40HP again
    note: even on the street the 3rd and 2ed fully slip and tcc line pressure not work, after 4the gear work
    this issue I have it as many cars and many TC not only for this car
    can help
    Mar 2011
    Ripley, MS
    1,865
    Post your tune and we can help you with this issue.
    Jan 2019
    49
    I posted now
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Max out the apply-ramp. Use the regulator offset/gain to set min pressure.
    Or just use the scanner to lock the TCC on the dyno... the "button" will get behind it with full pressure. Make sure you follow with clicking unlock right after the pull / before anything else sans lifting throttle.
    Steve Williams
    TunedbyFrost.com
    Jan 2019
    49
    Quote Originally Posted by Frost View Post
    I did other hpt the max pressure 110 PSI , still not fix
    Jan 2019
    49
    please check the VCM post
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by Rayan_V8 View Post
    I did, and I told you what to change.
    Steve Williams
    TunedbyFrost.com
    Jan 2019
    49
    I did it before your advice, no change
    Jan 2019
    49
    other car after I maxed at dyno, after full 100% tps the TC come Unlocked
    Jan 2019
    49
    here unlocked 2ed and 3rd gear with fully commanded locked in the street
    Jan 2006
    Richmond VA
    1,950
    Commanded gear control limits are stock 93 MPH / 5500 RPMs. If you are using the scanner to lock the TCC on the dyno in real time, the scanner controls will be ignored past those points. Set the MPH and RPM to max for those, and it should hold just fine with the scanner bi-di controls on the dyno.
    Steve Williams
    TunedbyFrost.com
    Jan 2019
    49
    thanks for answer
    still I don't know why the second and third gear not lock TUTD
