Results 1 to 5 of 5
Thread: MED17 No Lift Shift
    MED17 No Lift Shift
    hello, community.
    As you know, NLS function can be added to a raw dump by inserting a little code via "zwout_syns".
    I have a question....
    ...can it be done in vcm editor?
    on a cursory glance at the maps - i could not find anything that could help do this.
    GM FORD DODGE
    custom xdf for hpt
    Apr 2020
    11
    I would think user defined parameters should be able to do it.
    Create an XDF for it in TunerPro assuming you know the memory location.
    there are many means to do this,
    it can be done in tuner pro itself without using hptuners
    ...question is, can vcm editor do it?
    GM FORD DODGE
    custom xdf for hpt
    May 2014
    USA
    447
    this sound more like an OS modification, or is it purely a calibration change of existing logic?
    User defined parameters you can change anything in the calibration, but you can't write/change the OS/application software
    Quote Originally Posted by svvag2000 View Post
    You can open .xdfs from Tuner Pro with VCM Editor, so if you can do it in Tuner Pro you should be able to do it with HP Tuners unless it's outside of the allowed addresses.
