Results 1 to 8 of 8
Thread: Feedback on Tune for Turbo Silverado
    Apr 2020
    22
    This is a friends truck who had his truck built and tuned by a local shop. He brought it to us because it started making a knocking noise in the engine that turned out to be a rocker arm coming loose. During our inspection we found a slew of issues that we have since fixed (boost leaks, vacuum leak at fpr, questionable map sensor, fuel pump wiring, loose suspension, the list goes on). Once we fixed all of the issues, he asked us to look over his tune and to take a look at the logs and see if we see anything out of wack because the truck runs just awful. We installed an AEM Wideband and have it logging through the EGR.
    Truck Specs: P59, 6.0, 88mm T6, Bosch 210lb injectors, E85, big cam, 4L80, 3200 stall. His exhaust manifold setup goes around the back of the engine and collects into the bank 2 header, and then out the front of the bank 2 header into a collector for the turbo. Seems like a bad way to do it imo, but maybe it works, idunno, were not really LS guys so HP Tuners is something were pretty new to, especially tuning turbo cars on speed density.
    Tune File attached below. Supposedly made 800+whp like this.
    BobbyTune plus EGR enabled for AFR.hpt
    Upon initial start up, it seems to idle ok. It will idle cold around stoich, then slowly start to richen up.
    When trying to accelerate from a stop, it instantly goes lean with light throttle, and does not want to accelerate unless you give it half throttle or so. Then it finally wakes up and starts to move. During this time, the map sensor seems to read way off. With the key off, it reads 98kpa, but with a load it barely gets over 50-60kpa and it feels like it should be around 100kpa. I notice the map sensor linear and offset are wacky and do not correlate to a GM 3bar sensor but maybe a 4bar map sensor? The map sensor he has installed is part# 12623671. However when I try to use the 3bar data, the kpa with engine off goes to 70ish or even 50ish with different settings.
    Under WOT it takes FOREVER to build boost, but it does run in the lows 11s high 10s for AFR.
    Throttle never fully hits 100%. APP shows around 70ish and TPS shows around 70ish. He did say that his pedal wont go all the way to the ground bc of dynomat material under it. Can we adjust this? Or should we just cut that material out?
    Look at this VE Map... Like I said, i dont tune much on HP Tuners, tinker here and there, but in any VE map ive ever messed with on standalones ive never had values this low. I can only assume its due to a miscalculation in injector data for the Bosch 210s? Or is this normal?
    PE also seems to be useless, is this a Speed Density thing? Does it not use PE at all in this mode?
    Last thing, he says it goes into reduced power mode if he uses the column shifter to downshift and hold a gear rather then just using D.
    At this point, we may just contract someone out to remote in and tune it for us. Truck is really cool and has a lot of potential, and we just want to help him get it right! Thanks guys
    Oct 2020
    11
    pretty new at this but the map values look inccorect. also I believe the ve table is scaled so low because the injectors setting are stock 24lb per hour.
    Apr 2020
    22
    Quote Originally Posted by chopperrudy View Post
    We have ordered a LS9 Map sensor Part# 12592525 and the adapter harness so that it will plug up and fit properly in the manifold. Will re scale once that happens.
    Dec 2018
    Washington State
    182
    put it back into speed density and tune from there, right now its going to run terrible, I only took a quick look at the tune file.
    Apr 2020
    22
    Quote Originally Posted by DougO View Post
    Is it not already in speed density? There is no maf on the truck
    Dec 2018
    Washington State
    182
    Quote Originally Posted by SLEEPYDUB View Post
    Maf isn't failed correctly
    Apr 2020
    22
    only thing i saw to show it wasnt failed correctly was the high rpm disable still being at 4,000? What else did you see where it wasn't failed correctly?
    13,565
    Yeah that tune is all sorts of stupid. It was tuned with EFI live first it looks like too, that is not a stock OS that has been upgraded. It was flashed with EFI Live to a basically 3 bar OS, even though it only goes to 285kpa.
    The open loop EQ ratio is commanding 1.25 at all times, so it will ask for 11.6 AFR when it's not even in boost.
    The power enrichment table is set to 1.00, which is wrong as well. The Open Loop EQ ratio needs to commanded stoich, aka 1.00 at all times when at operating temp. The rest of the PE isn't setup yet either. I would do 95kpa map enable, 50% torque enable. The throttle pedal should be much lower like 50%. The RPM delay needs to be lower at like 1,500 and remove the 1.0s time delay.
    Injector data is wrong, it says it has 29lb/hr injectors and not 210lb/hr injectors. This is why the VE tables are pretty much junk.
    Timing isn't what I would call good. I'd make changes to it if I could but I don't have a MPVI2 yet.
