Results 1 to 4 of 4
Thread: Intermittent Logging 2016 Camaro
    Feb 2021
    10
    I've been using my MPVI2 on my sons 2010 Camaro and logging without issue. Today I tried it on my 2016 Camaro and it will log for like 5 seconds and then stop reading for maybe 10 seconds, then start again and repeat the cycle. Is there something that I'm missing? As I said, works fine on the other car so it makes me think there is a issue with my car but it seems to run fine.
    Any suggestions?
    I've attached a brief idle log and you can see how it is on then off over and over.
    Ray
    ATTACH]108141[/ATTACH]
    13,565
    Did you re-poll for supported parameters after you connected to your car?
    Feb 2021
    10
    No, but I'll give that a try.
    Feb 2021
    10
    Okay, apparently I'm a idiot. I went and re-tried, same results. I closed down VCM Scanner and re-opened re-connected to the car and it works fine now.
    Ray
