Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Fiesta 1.0T not enriching at WOT
  1. #21
    Jun 2019
    Wisconsin
    295
    I probably wouldn't worry too much about hurting it, it's not knocking and you're not tripping any excessive heat limits... Though *I* would trim back the LSPI load limits and put back a few others, just to keep it more "factory" safe.
    The only thing that looks out of place to me is OP Enrichment Requirement (ECM 44422) is disabled, it's enabled on all my 2.3L Ecoboost files (Ranger, Mustang, and Focus RS), I don't have any other 3 cylinder examples though.
    It is disabled in the V6 applications, but those tend to do things differently for some reason.
  2. #22
    Mar 2021
    18
    [ECM] 44422 - Optimum Power Enrichment Requirement: Switch that allows the requirement for fuel enrichment to enter Optimum Power mode to be ignored
    Well that's not a confusing description at all
    If it does what I think it might it could be my answer. If by "disabled" it means that something can ignore OP Enrichment mode that could explain it going to stoich at 4200rpm? If so I'll set it to "Enabled" and then it won't kick me out of power enrichment?
    I don't want to blast my neighbors with the open downpipe at 9:30pm but I'll give that a try tomorrow.
    Good point about the LSPI stuff, I was throwing stuff at the wall at that point hoping it would do something
  3. #23
    Mar 2021
    18
    Never mind, more searching leads me to think it doesn't do what I think it does. I should probably leave it disabled.
    https://forum.hptuners.com/showthrea...l=1#post557691
  4. #24
    Jun 2019
    Wisconsin
    295
    Interesting.
    So, with everything fully as factory, did it still not go into power enrichment?
    I mean it's only a 1L 3 cylinder, but as you said, stoich at 20psi isn't good for longevity and I find it odd that it would be like that from Ford...
  5. #25
    Mar 2021
    18
    Ok the mobile site is fully broken @HPTuners, I can't edit a post without deleting it lol!
    I haven't logged the full parameters from a fully stick tune, I will do that today and post it as well, that's a good idea.
    From other threads I've read and from the stock pedal enrichment table, I think the stick strategy is stoich until 5000+ rpm
  6. #26
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    Its torque control according to your log. Disable shuffle switch and relog.
