Hello all. fyi, I am new to this and I am not a professional tuner.
with that said I have a 2018 Camaro 1SS FBO, H/C (cam has 32% fuel lobe with LT1 stock hpfp) and flex fuel (currently running e75).
My injector ms is 4.7 at WOT, desired fuel rail pressure is at 2529 and it is giving out 2793. So I feel it's safe to say that I am good in the rail, injector and hpfp areas which leaves me to think I am losing pressure in the low side pump. It is requesting 73 psi but is only dishing out 54psi at WOT. It is currently a stock lt1 lpfp. AFR is between 14.6-15.4 at idle, and will drop down to mid 12's or 13's at WOT.
my ask is that someone please take a look at the log or the screen shot and see if i am indeed running out of fuel. Everyone keeps telling me I am ok, but then I read post on here and other sites that I shouldn't be running out of fuel still being N/A. Car only made 520 on a dynojet. I have a few more mods I want to add but I need to get this squared away first. Any information would be greatly appreciated.
Keep in mind, I updated the lpfp voltage from 15.5 to 16.5 just before this pull to see if it would help but it didnt. Prior to that it was still only only giving 54 psi. And yes I have contacted my tuner but have not heard back in a while.
