Originally Posted by
Hemituna
You need more fuel system.....130% duty cycle and 25ms could be a record, I have never seen em that high lol...
Get up over 100% DC and it will pull timing.
You are getting plenty of pulse width but still not enough fuel so is either pump/s, lack of pressure or injectors too small.
Once you have the fuel supply sorted out, do you have a boost referenced return fuel system? If you do table 34078 (fuel mass vs pressure difference) needs to be all zeros,
or if you still have a returnless system, that table needs to be scaled for boost to keep the VE table sane.
