Need Help on 2016 V6 Camaro 8speed
Hey this tune needs a lot of work.
This car has a ported manifold, L83 Throttle body from a Silverado with adapter plate, Rotofab Intake from a SS Camaro.
The problem is it idles in negative timing when in gear and when I try and add to the torque tables it causes a horrible idle surge.
Also with the bigger intake tube the maf sensor falls down to 1200hz at times but the tune only goes down to 1500 so I put it in VE only and failed out the maf and that's the only way I could get it to idle. Lastly this thing makes less than stock whp. I've got the fueling dialed in on a dynojet 224x and it makes a whopping 240whp with all of these mods. I know the throttle body doesn't open 100% at WOT which isn't helping but nothing I do seems to get this thing in line! Any help getting this car straight would be awesome! Log and Tune attatched.. jason16camaro.hpljasonv6portedmanifoldl83tbSSrotofab.hpt
