Hi,
I have a startup issue. While cranking, engine remains a few seconds 2500 rpm and returns to idle speed. When I reset pcm memory ( 11 fuse in engine compartment), startup goes only a few times normally again .
My car is a 05 300C 5.7 hemi with 6.1 hemi heads and intake manifold, dynatech with cat long tube headers, comp cams xfi 273h and 550CC injectors. The car run only E85.
somebody could help me?
Sorry for my bad english, I'm french...lol
Your IAT was 127* on start up, but I dont see any idle adders for IAT temp, noticed your MAP pressure is rather high as well (might be from the 6.1L heads/Cam). Try dropping your Idle-RPM-Maximum Setpoint to 1500-1600 RPM. May also need to adjust VE tables in Idle area for proper startup idle speed.
