Results 1 to 5 of 5
Thread: 04 GTO Ignition Timing Not Matching Tables
    Mar 2018
    12
    Have an 04 GTO I'm tuning and I cannot figure out what's going on with the ignition timing specifically when at WOT. The base timing doesn't match the high octane table.... It's close to the low octane table but there's zero knock. I am logging all the timing modifiers, all are zero and the base timing is low. Not sure why it's not referencing the high octane table...... What am I missing????
    13,564
    Weird that the channel engine delivered torque is reporting odd values, it sometime works and sometimes just takes a cliff dive to -66 ft/lbs.
    What is the intake setup on this? I see that on the last full throttle pull that the MAF sensor is dropping even while you are at full throttle still, which also makes the injector duty cycle/pulse width drop off. It hits 5,000rpm and the maf lb/min starts to drop off until you actually let off the throttle at 5,700rpm.
    Kinda looks like it's running off the low octane timing table. Those values are closer to what it's running for timing.
    What's the complete setup on this?
    Mar 2018
    12
    It's a stock LS1 GTO, just installed long tubes and a CAI. Throttle body, intake, cam etc are all stock. As far as the MAF dropping while on the throttle, honestly I think it's just the slow ECM processor and the logs may not be perfectly aligned? These gen 3 ECM's seem to log slow on the graphs in my experience.
    Potential Tuner 2NVIND's Avatar
    Feb 2021
    Australia
    7
    Hi Gents, very new and following on with interest while checking out the above log and tune.
    Is it possible that the condition is in relation to burst knock retard tables?
    2003 Holden VY SS UTE A4, SS Induction CAI, K&N, GTS300 intake, HM try y's, 100cell twin 3", 3.46, AEM X series WB, MVP12pro, STD tune currently.
    Feb 2021
    Australia
    7
    Quote Originally Posted by Roller75 View Post
    Have you come to a conclusion on this issue?
