Hello All,
I've got as the title says a 2016 Camaro SS that to which I added a Procharger, P1SC making about 7psi of boost at max RPM. The tune supplied from Procharger seems very rich. I've only recently began using HPTuners and I've done my first log on this car.
Anyhow, The first thing that I noticed is that my MAP max's out like at 117KPA and is clearly being effected by the boost. The Procharger install didn't have me change the MAP, so I'm considering changing to the DSX Baro Breakout. What do I need to know to change to this? I've done some research and realize that there is a range / initial / offset that needs modified. What else should I be looking for?
Ray
