Results 1 to 9 of 9
Thread: 2016 Camaro SS LT1 with Procharger MAP
    Feb 2021
    10
    Hello All,
    I've got as the title says a 2016 Camaro SS that to which I added a Procharger, P1SC making about 7psi of boost at max RPM. The tune supplied from Procharger seems very rich. I've only recently began using HPTuners and I've done my first log on this car.
    Anyhow, The first thing that I noticed is that my MAP max's out like at 117KPA and is clearly being effected by the boost. The Procharger install didn't have me change the MAP, so I'm considering changing to the DSX Baro Breakout. What do I need to know to change to this? I've done some research and realize that there is a range / initial / offset that needs modified. What else should I be looking for?
    Ray
    Aug 2009
    Calibrating
    3,376
    Procharger doesn’t know crap about tuning, got into with them years ago about these on corvette forum.. baro needs to be broke out to be right on both fuel models..
    Get Dave’s kit..
    Needs ls9 or equivalent map sensor to read boost (its plug and play)
    Once baro sensor is broken out from MAF hosts leave it open to atmosphere and will read correct baro and not get skewed from boost
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2007
    489
    Ben is 100% on point, PC told me the same thing as well. 1st thing Jannetty Racing had me do is break out the MAP and add the 3 bar MAP into the intake manifold.
    Nov 2009
    All Around
    3,149
    for the torque model to work properly its a must
    Feb 2021
    10
    Okay, I'll get one ordered. So other than the items listed above initial, offset etc, is there anything else that I need to change?
    I was a little surprised at how the tune was modified. Sort of expected more.
    Dec 2019
    48
    Can you post/send the PC supplied tune, I am going that route soon and Im curious the changes they make compared to the stock GM file.
    Thanks!
    2018 Camaro 2SS A8 Redline Edition
    Feb 2020
    Central VA
    54
    When you say it seems rich, how rich is it? Do you have an A/F gauge? You need one for tuning. I have mine reading Lambda and running .87-.88 @ WOT
    2017 Camaro SS, Flow Tech axle back, Roto Fab, Nick Williams 103 TB, BBK long tube headers, Magnuson 2650, Snow Performance Water/Methanol Injection.
    Aug 2009
    Calibrating
    3,376
    I wouldn’t run the supplied tune... I also wouldn’t run a boosted DI GM engine at .88 lambda in boost either
    14 Gen 5 Viper
    Feb 2020
    Central VA
    54
    Right, I'm non boosted right now. I am waiting on a Magnuson 2650. I was just wondering how he was determining that he was running rich. I'm guessing PC made the tune rich to cover their warranty.
