Results 1 to 4 of 4
Thread: Question on changing vins
    When swapping a pcm on a vehicle, must I license both vin numbers or can I just license the pcm I'm swapping in and then change the vin to match the vehicle? I'm having issues changing vins on a e78 pcm (2014 sonic) and the vehicle is immobile because of VATS. Any help would be greatly appreciated!
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,264
    Yes you must have a license for both vin's and if the os is different you'd need to have a license for the new vin/os pairing you create. I would suggest using our vin changing only as a last resort. Your best bet is an OEM flash device, you flash in the vin/os pairing you want, then read/license using our product.
    Unfortunately I have spent the 4 credits to license both vins but it still for some reason wont take the vin. I have tried it every which way I can possibly think of. I tried changing it through the editor (which says it was successful), through the scanner (which says it failed) and I've tried doing a "write calibration" and "write entire" after completing the "successful" vin change in the editor. After every time, the security light is on and the vehicle is immobilized and when I re-read the tune off the vehicle I just flashed onto it, it keeps coming back with the incorrect vin.
    HP Tuners Support
    (foff667)
    28,264
    Your best bet is using an OEM flash device to flash in the vin/os pairing you want
