Hi, new at this so bear with me as a new guy to the forum and tuning. I have been doing a swap into a 70 c10, engine started out as a 2004 6.0 lq4 complete engine with harness, pcm, and trans. Long story short, its a 394(4.005x3.900) stroker with a ls3 top end and comp lsr cam, i rebuilt the 4l80, long tubes, 3 inch with a X-pipe. After getting burned by both crank and cam sensors because i bought generic parts house sensors, i finally got it to fire every time i turn the key. The issue I have is that it stalls when taken out of park and doesn't start in neutral. I have read many post about the moderate cam and idle tuning, but this seems more like the ignition is switched off, like i don't even feel the trans engage like a bad converter or insufficient power to stay running. If you brake torque it, two foot it, it shuts down the same. I found mention of a setting in system>general>vehicle options that relates to this, but not sure what it would be. I feel like this is a either I wiring snafu I made, or a setting I need to change. I am putting up my current tune, it is pretty stock save for some idle, general, and fuel tweaks. Any help is much appreciated. then i can start actually dialing in the fuel on this thing. -Thanks
