Results 1 to 9 of 9
Thread: 18 silverado . Need help with tuning
    Jan 2021
    29
    So heres the issue, We did a header install on the silverado and removed the rear o2 sensors while leaving the fronts installed.
    After we installed the headers and cranked it up the truck would idle very poorly like was running too rich,
    I disabled DOD, COT in both Engine and Engine Diag so far. What am I missing.
    Seen a few where guys do this same install and fires right up fine.
    Double checked all the plug wires to make sure they are properly seated in
    I WILL POST LOG TOMORROW
    13,582
    Not that this would make it run poorly but did you also turn off the rear o2 sensor codes and cat codes?
    Oct 2018
    44
    Were there any codes? Is there any loose vacuum lines? Possible cracked porcelain on the spark plugs?
    Look at LTFTs and misfires for all cylinders to see what's going on.
    Log LTFTs and misfire to narrow down potential causes.
    2016 Silverado CCSB L83/6l80e
    TSP cam 218/226, .635"/.635", 113 LSA 10% FL
    TSP LT headers
    Circle D Billet converter
    Nov 2009
    All Around
    3,149
    a log will show for sure what needs to be addressed
    Jan 2021
    29
    There was only codes for the rear o2s which I removed from tune file and cleared them, also got a code for random misfire which I also cleared
    I will attach the stock tune here and maybe let me know what to adjust
    Im waiting for customer to bring back the truck later today get a fresh log
    18 silverdo.hpt
    Jan 2021
    29
    Heres the log file at idle, the spike are me barely tapping the gas idle
    I assume the red is really lean , but The way it feels tapping it feels really rich like no power
    I did light reasearch on this Gen that the VVE table needs to be adjusted along with MAF table
    but this truck idles very pour
    Jan 2021
    29
    GoT ITTTTTT!!!!! im dumb..... VE table was the issue, i was way too lean
    13,582
    Why would you have to add fuel to the VE with just a header install?
    Bank 1 clearly has a issue, hopefully you actually fixed that and didn't just slap the tune with more fuel.
    Nov 2009
    All Around
    3,149
    you could have a misfire showing lean condition, maybe broken ceramic or plug wire during install
